Hey, I don't see fuel injection on the list!:eek
I think Hijinx is giving some good advise there. Carbs are usually the subject of much frustratiobn and
ad on these forums.
I think where most people goof up is not matching a carb to the car, and the driving characteristics of the owner. The Edelbrock Performer is just plain purrrrty. They work fair, and typically take a stroke of genius or luck to dial them in the first time.
The Q-jet direct replacement makes the most sense. However, if you have mods done to the engine, chances are it won't be right either. Plus Q-jest is also difficult to dial in if needed (metering rods, etc).
Getting one from a local autoparts store is okay for a stock engine, but then again it may simply be a generic equivelent and never run quite right.
For the performance oriented, the Demon, Street Avenger, etc. etc. over a wide range of performance and quick change tuning.
If it is all stock, go with the most direct stock replacment, do the idle set tuning, slap the air cleaner back on and enjoy the car.
If performance minded, take your time and match to the overall package for best results.
Did I mention fuel injection? Actually, you can get a used TPI manifold from a 85-92 Camaro, or 85-91 Vette for around $100 to $250, a wire harness for about $250 and $100 chip. After some other messing around with fuel lines, etc. You can be running C4 performance and technology and leave the old carb tuning in the dust. Plus, you may get an extra mile or two per gallon, instant cold starts, and the ewwwww, aaaaaaa, factor when you pop the hood at a show.
