- Thread starter
- #21
J
jsimpson
you're on target! For $2600 to $3800, I'd be getting a used complete LT-4 or LS-1 instead of a TPI unit!
Hijinx said:Chris, I will definately pick you brain. Here are some initial questions;
1. Will I need to make exhaust changes, beyond putting the O2 sensor in? Will this work with the Ram's horns or will I need to go to headers?
You can drill and tap your ram horn for the O2, or, have the local muffler shop weld an O2 bung into the upper part of the pipe about 5" down from where it bolts to the manifold. My local welding shop keeps those threaded O2 bungs in stock as they have become a regular part of exhaust work.
2. Will I need to make a cam change or other valve train changes? Seems that I saw a post on this at some point and that these systems look for some specific cam lobe designs?
It depends on your cam. TPI will work with most cams as long as the lobe seperatoin is 112 or greater. Many older style hot cams use a 110 to 108 lobe seperation. That will cause vacuum problems. You can get a complete 2050 flat tappet Crane Compu cam and lifters very reasonable in price. Get your specs first, as you may not need to change anything.
3. With the Ignitor II installed in my original distributor, can I retain this and not switch to HEI?
This may cause a problem if you are still running a cable tach drive. You wil want an HEI. The good news is you can get a rebuilt HEI at most auto parts stores for $99, and one from the junk yard for $30. You can sell your stock unit for well more than that, or save it for a future "return to stock".
4. Will it work OK with my existing A/C, alternator and valve cover setup?
It should. Open your hood, and draw a mental line just above the water neck and straight to the radiator. As long as that does not hit anything (belts, brackets), you are clear. A Serpentine set would look better, but I don't imagine you will have a problem. There should be no problem with a/c, etc. You can run tall or short covers with TPI and not have any issues.
5. Will I need to run the evap canister any longer and how does this change the vacuum line setup? Especially with the brake booster.
The TPI has a port for brake vacuum booster and PCV. You will hook it up just like the Camaro it came from. You will still want to hook up the evap line to reduce gas vapor smells in the garage. You will need to tag into the vacuum port just under and behind the throttle body to run to the stock Evap line. I installed a EVAP in my 69 to keep the stinky smells to a minimum. That allows you to run a non-vented gas cap.
I'll think of more questions, but that's it for now. Thanks
