B
bob_robert
I want to replace my present "Electric" Water Temp & Oil Pressure gauges with "Mechanical" ones. I'm sure that someone has already done this to their Vette.
I have a 78 and would like to know what size and brand of gage will fit into the existing gauge openings. Also I will install tee fittings so that I can use the existing "Electric" sending units to power some additional Idiot Lights.
I have another question also. I'm going to replace my existing Radiator Fan with a 18" Perma-Cool Stainless Steel Flex Fan. Has anyone used one of these and if so what do you think about them. Also my engine is a 406 CI with a HD Radiator and a stock shroud. What size Fan Spacer should I use. There is about 4" from the water pump mounting flange to the closest part of my shroud so I think that a 2.25" would work but I'm looking for advise. Lastly has anyone used any of those Radiator Cooler Additives such a "Purple Ice" , "NOS Super Coolant", "Water Wetter" , etc. Do they work or is it just "Snake Oil"
Thanks in Advance for your help.:confused :confused :confused
