Driftwood
While I'm installing a new oil pan gasket on my 69 350/350 SB, I'm considering also replacing the oil pump. Any suggestions-- stick with GM or are there better high performance parts to use? Thanks for any info.
Driftwood said:Yes-- I'm planning on changing the upper rear seal also. I'm going to try a one-piece oil pan gasket. Oil pan gasket, rear seal, and oil pump. Anything else I should do while I'm in there?
Assume that's at hot cruise ... 55psi sounds good.Driftwood said:With the Melling M55 replacement pump my pressure jumped from 35 to 55 psi. Does that sound about right for a 350/350 with 10W30 oil?
