replacing an LT1 fuel pump
grumpyvette
Loxahatchee, FL, Palm Beach co
IF YOUR LOOKING TO JUST REPLACE A DEFECTIVE PUMP ILL OUTLINE THE BASIC STEPS
its not necessary to drain the tank but its a good idea to do so,
step one have the parts on hand PLUS 3 ft of 3/8" fuel line and 1 ft of 5/16" fuel line , I know, you may not need the fuel line but in many cases its faster and easier to remove the old line and replace with new ones
hose clamps, youll want several 1/2" size for the lines
fuel pump
http://www.ecklers.com/product.asp?pf_id=30666&dept_id=1277
fuel pump screen
http://www.ecklers.com/product.asp?pf_id=30668&dept_id=1277
fuel filter
http://www.ecklers.com/product.asp?pf_id=A3479&dept_id=1303
(optional but a GREAT IDEA)
ok, step one,
make darn sure the keys are out of the car and the battery is disconnected for extra safety
step two, open the fuel fill door center rear deck where you normally fill the car and remove the gas cap
step three
remove the four very small torx screws in the corners and lift off the door assembly
step four
theres a rubber bib fuel spill tray)(around the fill spout, remove the gas cap and work the bib fuel spill tray ) (out , and disconnect the water drain line and label it with masking tape/pen
step five
label the three lines with masking tape/pen (upper line/lower line /left side line)
remove each at the central point in the opening, then disconnect the electrical connector on the lower edge of the opening
step six
remove the 8 10mm bolts and look carefully at where the components go, after they are removed the pump lifts up and out, the pump normally comes with instructions also, but its fairly simple, the pump, lines and fuel level sensor lifts out as a sub assembly, look thru the link below for pictures and more info
NOW IF YOU WANT TOO UPGRADE HERES A MORE USEFUL LINK WITH PART NUMBERS
http://www.caspeed.com/boschpump/boschpump.html
