toobroketoretire
Banned
A novice can get awfully frustrated while trying to install new brake pads because the darned pistons won't stay depressed long enough to insert the pads. He'll push one piston in and the other piston pops out and when he pushes that piston back in the other piston pops out (???). The reason the pistons won't stay depressed is because there is brake fluid behind the pistons. By taking the master cylinder lid off and opening the bleeder screw the fluid behind the pistons can escape and the pistons can be depressed long enough to install the new pads. Here's how you do it:
1. Remove the old pads.
2. Remove the master cylinder lid and OPEN the bleeder screw.
3. The OPEN bleeder screw will allow the fluid behind the pistons to squirt out as you use a 6" wide steel putty knife to depress the pistons and install the pads.
4. Once the new pads have been installed and the cotter key put back in close and torque the bleeder screw to 90 in/lbs and top off the master cylinder.
