MaineShark
- Joined
- Sep 21, 2002
- Messages
- 1,326
- Location
- Rockingham County, NH
- Corvette
- 1979 L82, 1987 Buick Grand National
I have a feeling my rear spring is getting tired.  It seems softer than it should be and the car doesn't quite sit level.  So, with less exhaust clearance than I used to have, I think I'd like to replace it with a new (maybe slightly stiffer) spring.
How involved is the replacement procedure, for a home mechanic (ie, jack stands, not a lift)?
And, how much more complicated is it to do the replacement without removing the exhaust pipes? When he installed them, my mechanic welded them ( ad ), so removing them will be nearly impossible without damage, I think.  Is it going to be possible to slip the spring out and in above the pipes?
Joe
ad ), so removing them will be nearly impossible without damage, I think.  Is it going to be possible to slip the spring out and in above the pipes?Joe
