J
johnny80
Hey guys..been a while since I have posted. I have run into my biggest fear with my 1988. While on the interstate, the OD kicked off several times. Got her home, looked under her and saw the 4+3 was leaking ...tightned up the bolts... added fluid..still leaks....Had AAMCO put it on the rack to check it for me and they found metal bits in the fluid as well as it being a bit low. They tried to assure me that they could fix it but I told them no. They didn't even know what a 4+3 was and I had to explain the shifting procedures to them when they test drove it. Plus the SES light stays on...they (AAMCO) says its a code twenty something ( I forgot ). Bottom line is they wanted around 700.00 to take it apart and see what was really wrong plus another chunk of change for differential repair. That was not including the price of either rebuilding/parts/labor...that was just to take it apart and look. I then called Corvettes of Auburn...they say pretty much the same thing...a lot of money to take it apart...look at it...assess the damage. 1300.00 for a 4+3 not including labor plus alot for the rear diff rebuild....total....about 3000.00 if I am lucky. I saw in my new Ecklers catalog about the Richmond 6 speed and looked at the installation procedure that is on the website...there is a bit of cutting and refitting....plus the richmond 6 alone is 3400.00 and I could imaging the price of getting one installed. Guys...I love my car...I had her painted over the summer...detailed often...even found the 17 in rims that came with her originally..had them detailed and polished. Bottom line is that I can't get rid of her. Any guidance would be great.
