When you jump pins A and C, turn on the ignition. Watch the SRC light flash. There is a specifc sequence of flashes you have to look for.
At the start, a Code 12 is flashed three times followed by a pause, and then any specific codes stored, followed by a Code 12 to end the sequence. The code numbers are counted by the blinking sequence. For example, a Code 12 is one blink followed by two blinks. There is a half-second pause between the two numbers This is done three times:
blink
blink, blink
blink
blink, blink
blink
blink, blink
After a three second pause the code (or codes) will start to flash. A code 23 which is caused by cycling of the ignition switch three or more times with out the car moving is:
blink, blink
blink, blink, blink
this is repeated twice more and then goes on to the next code. After all codes are displayed, Code 12 is repeated. Shutting off the ignition switch will stop the code display.
Here are the codes:
23 Loss of vehicle speed signal (ignition switch on 3 times etc.)
13 and 22 Left Rear or Right Rear Time Out (tests actuator moving to a stop
14 and 21 Same for Right side
41, 42, 43 SRC Swithc Circuit Fault
Codes 13, 14, 21 and 22 can indicate either a bad actuator or a bad shock gear or shaft. YOu will need to remove the actuator and check the gear condition. If the gear is broken (a common occurance) the shock will have to be replaced or repaired. If the gear is good, you can clear the code(s) and swap the actuator side to side and check codes again. The actuators can't be swapped front to rear as the cable lengths are different.
Clear the codes by grounding pin C for two seconds and repeat twice more.
Bilstein will repair the shock for around $65. They can also revalve the shocks for different applications. You can call them at 1-800-537-1085 in Poway, CA near San Diego. I just sent a shock off to them with a broken gear and it will take about 2 weeks to get back. The gears are not sold separately and the actuators are a GM item. eBay may be a good source for actuators if you need one.
