After replacing my rocker arms last fall (with roller-tips), I've come to realize I didn't tighten the valves properly (mostly by the sound/feel of the engine). So today I went to try and adjust them again.
So as I'm working my way around the firing order, I've got a chart I'm following from last time (starts out TDC: 8 exhaust, goes around past TDC: 5 exhaust, etc). Maybe I'm mis-remembering, but I thought I could adjust both valves that say to be adjusted at TDC (ie, 8 and 5 exhausts). However, though 8 stays fine, as I keep adjusting other valves #5 gets WAY loose again. Then another one does the same thing. As I look at them, I realize that TIGHT on some arms is nowhere near as tight as on other arms (the nut isn't screwed down anywhere near as much). The pushrods for almost half the valves I'm adjusting are UP, keeping the arms from seating as far down as they should be. Am I adjusting in the wrong order? Is my distributor rotor on 180 degrees off (It's the one that was on when I got the car)? Should I only adjust ONE valve per 45 degrees, rather than TWO?
I do know I have the shafts lined up right - I took a plastic bowl, cut off the rim, and made a template using the spark plug terminals on the distributor cap so I could make sure the rotor is lined up with each terminal properly (and when I came back around to the #1 wire, the TDC mark was about 2 degrees off, which is pretty close I think).
Any help is appreciated...
Thanks!
[RICHR]
Thanks!
[RICHR]
