C
C4 Guam
First off thanks to the folks that have answered previous posts, the information was helpful. The engine re-build went well and it's back in the car and running. I'm having a bit of trouble getting the rocker arms adjusted. Used two different techniques that use to work on standard hydraulic lifters but I'm ending up with the rockers either being to tight or to loose when I start up. I think I'm not getting the lifters on the absolute backside of the cam when adjusting. Any input on the correct sequence will be greatly appreciated.
Motor sounds real good, bumped compression up to 10:7, ported heads, advanced cam at crank, performance plenum, headers, and flowmasters. Sounds like a 60's version.
Regards,
Fred in Guam.
Regards,
Fred in Guam.
