RON G Hi I am a new member have a 1984 vette.
ron g
New member
detroit
1984 coupe,1976 project street rod corvettes
HELP:mad TPS im getting a code 22 which is a throttle position sensor well I replaced that still getting code 22 I was told to change my computer I did still getting code 22 then they said it was the prom changed that still getting code 22 even changed then o2 sensors still getting code 22 then I was told it is a bad ground HEEEEEEELP WHAT GROUND WHERE IF ANYONE OUT THERE CAN HELP I SURE WOULD APPRECIATE IT. THANK YOU IN ADVANCE
Welcome to the Corvette Action Center. Your thread belongs here - in the C4 Tech forum instead of the New Member Introductions.
If 84 is the same as 89 there will be 5-7 wires (grounds) attached to the lower bell housing bolt on the drivers side. Some of them are grounds to the ECM.
Whoever said to replace some of whats been replaced was playing a guessing game. It would be very unusual for the ecm or eprom to give only that fault when they fail.
Was the new tps adjusted correctly when it was installed? (Most likely was just want to be sure)
as well as noted about grounds above check continuity from the tps back to the ecm on all wires
h
how do you check the wires from the TPS to the ecm thanks ron g
