Question: Roof Panel Carrier
krscholz
Caldwell, ID
75 Corvette Coupe, 383 Stroker
Does anybody know where you can get a roof pannel carrier that mounts on the luggage rack for cheap?
Do you mean the factory t-top carrier or the one that mounts to the luggage rack????
I just found one on ebay. However, is there a problem with the rack being a 6 or 8 mount type?
The 8 hole rack is the one you need. It has to have the mounting pins for the brackets on the two outer bars and the two inner bars. I have several sets what are you thinking price wise when you say cheap?
My t-top carrier is oem,and only has 4 holes on the back deck.
Sent from my DROIDX using Tapatalk
Looks like his is a 75 and yours a 81 completly different.
...Looks like his is a 75 and yours a 81 completly different...
Correct; they're different, but both carried the V54 option code.
6 hole racks do not have pins to mount the optional V54 hardware; 8 hole racks are supposed to have the pins.
Be aware there is an aftermarket hardware kit to mount the t-top carrier hardware to the rack which does not require the pins. It uses clamps.
:thumb
Not intended as topic -jack, but would you have a picture of the carrier installed, without the T-tops, Bill?
I have the 4 mounts, but not the carriers, and would like to see them; what wording would work when searching E-bay?
Thanks,
Cor
When I get home
...Im in effingham for the. Rest of the week.....
