- Thread starter
- #21
F
FForward
I replaced the o2 sensor and checked the grounds recently and I still have the slight miss plus a little surge at times. I was wondering if the ESC has anything to do with it. It has never been replaced. I disconnected it while the car was running at idle and nothing happened. As it now stands the complete fuel system has been replaced from pump to injectors. The ignition has had all new plugs, wires, complete dist., and timing is set to TDC. The EGR was replaced and I checked for vacuum leaks with the propane method. It happens in both open and closed loops. The TPS seems to be operating ok and is set to specs. The IAC was cleaned along with the throttle body when the new injectors were installed. The MAF, IAC, ESC, and TPS are the orignals. Because I have the Bosch Gen III injectors it was suggested that the fuel pressure regulator be disconnected from the vacuum line. It was also suggested that I shouldn't do that and so I hooked it back up again. No difference either way. The engine is running lean according to what the diagnostic machine read. Still no codes showing and the car runs basically really good inspite of the miss. I did forget to mention above the ECM and a Hypertech chip were recently replaced also. I continue to drive the car in hopes the the ECM is still in the learning stage and will correct things, so far it hasn't. Any other suggestions would be greatly appreciated. Thank you all for previous suggestions.
Come to find out, the spark plugs installed, when the first shop did the "standard fix," which really didn't fix anything, were defective, or incorrectly installed. Two of them had cracks in the ceramic insulator and were apparently grounding out. The #1 and #2 cylinders were both affected. It makes me think that the tech over-torqued them while installing them. Not for lack of trying, but I've resigned myself to just putting up with the rough idle because none of the shops I've taken it to can seem to find a reason for the rough idle. Like you, I've replaced the entire ignition system, including the coil, distributor, ignition module and ESC, the fuel filter & pump strainer, the EGR valve, the valve solenoid and all associated vacuum lines, and checked the engine grounds and TPS. The last shop I took it to (the ones who found the screwed up spark plugs) did some kind of special test to check for air leaks around the runners and plenum and couldn't find any leaks there either. The only thing I haven't changed is the MAF sensor, which the last shop supposedly cleaned while cleaning the IAC. The only other thing I haven't changed is the O2 sensor, but on a recent trip from here in Mesa to Las Vegas, I averaged 28MPG, including driving on "The Strip," which as you probably know is bumper-to-bumper traffic on the weekends, and that was with the A/C on the entire trip.
