- Thread starter
- #21
C
ctjackster
the clock rebuild . . .
Changing the points, setting the dwell and timing. Of course that was the last thing I did, so everything else probably helped or fixed other issues. Such as the carb rebuild, you could smell fuel after shutting down before the rebuild. The fuel filter/pump, wires/plugs.allcoupedup said:Is it running properly? What did the trick?
Just throwing in my 2 cents...Mine also does this, but usually at 60 MPH...[Note: have 3:70 gearing]...So I think it's normal...thaus65 said:I am the new owner of 65 convertible 327/365, 4 speed no air, power anything w/#'s all matching original knock-offs's and side exhaust that has been run about 200 miles over the past several years. I am just in the process of investigating and repairing the few items I've found...
I would appreciate your thoughts and guidance in a few areas:
2. While driving around over 1,500 RPM the shifter rattles extremely bad! Is there a rebuild kit or is replacement required? Also, is this an indicator of a loose transmission or engine?
I've been scanning the board and have picked up a lot of valuable info, thank you in advance.
