chevyaddict
Hi all;
Ok, so I searched the forums for RPO codes and build sheets. I also looked under the tech center - model center for info and I'm finding inconsistencies all over the place so perhaps you guys can help me out.
First, I read on one thread that they didn't put build sheets in 68 Corvettes, and yet on another thread they did. So did they or didn't they? Are they on the gas tank if they are?
Secondly, is the build sheet the only way for me to extract RPO Code information? I assume yes but I'd like confirmation of that.
Also, the tech center here lists the HP block as a 350 HP, but in two other sources that suffix code is listed as a 300 HP. How can I find out for sure? Also, I'd like to findout camshaft lift and duration, compression, confirm the rear axle ratio and just more specifics..... any ideas how I can find that info easily?
Danka all!!!
Danka all!!!
