vetteman741
Has anyone had this same problem and fixed it, I am wondering where I should start.
So this is what happens:
I turn on the ignition and all the running lights start flashing, faster than hyperflash. I have all normal bulbs and completely stock. Also, turn signals in front do not work. Then, when I turn on the lights they stop flashing but the left turn signal dash indicator stays on and left turn signal does not work, the right works fine in rear. The flashing tick noise is coming from the DRL relays under dash, if I take out the L-DRL relay it stops, if I take out the R-DRL relay it keeps flashing.
I took off both ground packs from the front frame rails under hood and cleaned them, did not fix. I guess I will probably start with my Left DRL and signal sockets although they light up fine, maybe they have a wire crossed or something:confused. Thank goodness I bought a GM repair manual a couple of months ago.
