95ZR1#418
- Joined
- Apr 26, 2002
- Messages
- 120
- Location
- Missoula, Montana USA
- Corvette
- 95ZR1#418, 88Z51Coupe, 69L46Coupe
Hello All-
All power/ignition off. Checking solenoid mounted in car. I disconect the dual vac plug connector from the solenoid. I pull a vac. from the passenger side vac. nipple of the solenoid(this would connect to the vac. reservoir), there is a steady decrease in vac here wether the driver side nipple is plugged or not.
There is no way to pull a vacuum on the driver side nipple, is this faulty or because the solenoid is not activated? This nipple from the solenoid would connect to the actuator lines.
The actuators open and hold without vacuum leakage from the two's common connection (that which would plug into the solenoid).
Do I have a bad solenoid??
