C
CharlesBrown
After setting the security door lock on my '88, I know the horn will go off if someone trys to get in the car. Does this "system" do anything else i.e., disable the electrical or fuel system?
That is the correct procedure for verts for sure. However what may not be clear from the previous post is that for me power locking the door will arm the alarm.
Now my bro's vert has some special key that fits into the side of the dash that is a kill switch. It looks totally stock, and we have not found anything on the car that looks different then mine, so I assume this is a factory item, although I could be wrong.
However for now the only thing that stops that alarm is unlocking the drivers door. Not even getting in and starting the car will do it. I have unplugged the horns because I didn't want to lose all the dash data. Sure enough the horn relay will stop, but as soon as either door opens the alarm will start again.
