GiDvEtTe84
I have an 84. This only happens when its cold (about 50 degrees F and under) My brakes seem very hard, especially if I apply them quickly. It feels as if the booster is not working. My booster and check valve are rebuilt/new and the master cylinder is only a couple of years old as well. It seems like there is good vaccum to the booster but its hard to tell. The line from the intake to the booster does not seem the have any leaks and my engine does not run with a high idle like I would have a Vac leak. I really need to get this figured out because its nearing winter time. I would also like to ask if anyone has a diagram of the 84's vac lines. Thanks.
