HallenTi
In a service bulletin for 1984 Corvette with Z-51 suspension, Chevrolet suggests the following:
"Ride harshness associated with the Z-51 suspension option may be a source of concern to some customers. Ride harshness can be significantly changed by reducing the cold tire inflation pressure from 35 psi to 26 psi. Operation at a tire pressure of 26 psi could result in a slight decrease in fuel economy and a slight increase in tire wear dependent on driving habits."
No other years are listed here. I have the Z-51 suspension, with the FX-3. Although I sometimes kinda like the "taught" feel of the suspension, I was thinking of trying the lower tire pressure to see just how much difference it makes. However, I know that changing the tire pressure from recommended can affect tire wear as well as fuel mileage, and wondered if others have lowered theirs. I'm interested in seeing any long-term ill-effects from lowering from the recommended 35 to something between the suggested 26 and 32 PSI. I do not drive very aggressively, and have the stock Goodyear tires. Thanks, Tim
