- Thread starter
- #21
S
SLICKMAN
I just purchased the bypass kit and I'm putting it in when it shows up. I'll then say good by to this problem for ever:bang
singledad_9 said:It happened again....
My gut feeling is that it is heat related. When ever I go on a date and it's hot outside, it happens.
SLICKMAN said:This is the first time I ever heard of this? There are many out there using this item and I would think there would be posts all over this and other forums if this was the case.:eyerole
c4c5specialist said:HI there,
Yes, I would only want the factory installation for the repair.
It has been proven that the bypass does NOT adequately load the BCM, and can show problems down the line.
You will always hear the lock cycle. This is part of the repair, as the actuator still provides electrical load. The other side to this is a feedback relay, and a lock plate that does NOT allow the actuator to engage.
Allthebest, c4c5![]()
