B
Bullitt
I need some help, advice, ideas and information from anyone whom has thought of performing this swap or with in-depth knowledge of steering components. Okay, it's getting near decision time for me on whether I should attempt this conversion or not. Granted, I've only been thinking about this for a few weeks, but I'm at the point of wondering if updating to newer technology is worth it. I spent some time searching the net and read about systems for every other car. :eyerole There seems to be some worry about the strengh of the Steeroids systems for Camaros. It's a front steer vs. a rear steer design issue. By having the r&p up front, it's not required that the rack to be terribly strong or stiff. The theory is that brake loads on a rear steer system (behind the spindle) like Steeroids do require a strong and robust rack or failure will occur. Is this a moot point on Corvettes because of the stock configuration? The types of rack also came up, with some wondering where SpeedDirect gets their stuff. Another site I found, had a design for a system that required the r&p body to move, instead of the ends like a conventional design. Links were placed from the center of the r&p unit (Saab style) that relayed out to the connecting tie rod ends. It used bracketry (that would have to be fabricated), that would bolt up to the former locations of the steering box and idler arm. The problem seemed to be aligning the column with the rack. The guy who performed this conversion had to collapse the sterring column to get it to work right without binding the steering.
The advantage of his system is the fact that most parts were sourced through the junkyard or parts cars. That means CHEAP! I'll look for the site and try to post a link, later. I would like to lessen the weight of the car and tighten up the steering at the same time. My alignment was a out of shape and the steering wheel had some play before I put my '71 on jackstands, so I'd like to fix that. Help!!!--Bullitt
