R
resto75
I have a shift kit in my 94 and it shifts firm from 1st to 2nd gear and you will notice when it shifts. The higher gears the shift is not so noticeable and are softer in the shift. I haven't noticed a shift problem in the rain if you drive carefully and slowly as you should in the rain. I have 315 tires on the rear so that might help with traction however.
