shift lockout
  • Thread starter Thread starter walruscontroller
W
walruscontroller
Had my manual transmission keep me from shifting into third. Then worked well for a while, after which I could only shift into reverse and sixth. Now works normally again. Called dealer who said a similar problem was undiagnosed. Any thoughts? Linkage?
CAGS? Transmission? I appreciate your input.
Have you disconnected the CAGS or is it still functioning?
CAGS still connected. Can CAGS go wild and lock out other gears besides 2nd and 3rd? If I disconnect unit, which plug seal set should I use or is there only one? Has anyone heard of this problem? Thanks.
