Johan
I'm installing the shifter linkage. Has the inner holes on the gearbox shift levers any purpose, i.e is it possible to install the linkage to the inner holes and get a shorter throw when shifting?
how big of a pain was it to install the hurst shifter? I have a 81 I want to swap one in. Did you do it with the trans in or out? I might do mine with trans out since the throw out bearing is making noise.
