Whenever I drop the car down into 1,2,or D the shifter does not lock. I can put it in 1 and slide it up into overdrive with one push. Is the cable just loose?Also, what temp a good running condition? She is running at about 225-235(max)?
Jeb said:The shifter only locks in Drive(O). It's not supposed to lock in D, 1, or 2. I believe it's designed to lock there only because that keeps you from shifting into reverse from a forward gear by accident.
