Automatic or 4 speed? Automatic shifters can be removed from inside the car with the exception of the shifter cable on the transmission. 4 speed shifters have to be removed from under the car. The assembly instruction manual (AIM) shows both installations.
You will need to remove the console side panels and the shifter plate in order to have access to the shifter.
