Side terminal POPPED OFF!!!
KANE
Moderator
KY
Dark Blue 1982 Trans Am(s): Polo Green 1995 MN6
Yeah- just what I said!!!!
The threaded terminal on the side of the battery LITERALLY FELL OUT when I went to replace the dead battery.
A little acid had seeped out, but luckily the baking soda found all of it before it could eat the harness apart!!!
I guess this was a common proble for the C5s from some of the posts I have seen. Anyone else seen this or had an acid-eating-into-the-harness issue?
Yep, big time problems.
As long as you hit this before the acid went below the battery tray, you should be just fine.
Otherwise, I would remove the inner fender, battery tray and perform a full check of all wiring to make sure that there is nothing left to eat the wiring.
Allthebest, c4c5:hb
