gsimpson9981
Active member
on 80 - 82, has anyone had a difficult time removing the half shafs after removing the snap ring? The end of the shafts look like they have been burred, and the shafts will only move out until this area hits the spider gears. Also, the cross shaft (between the yoke ends) is burred. I see the cross shaft wont come out with the ring gear in place. If one unbolts the ring gear, will it slide over enough to clear the cross shaft. I really hate to try to remove the posi assembly. By the way, this got started because I wanted to replace the leaky side yoke seals.....alas, the vette up and bites me in the arse....
