In either the 1978 or 1979 Chevrolet Shop Manual, Chevrolet recommended, for the first time, sealing the piston to piston seal using RTV, a move I believe to help prevent moisture collecting in the caliper bores.
Back around 1980 -1981, I converted a 1978 to silicone brake fluid, and as far as I know, it still has silicone in it to this day. The car also received Vette Brakes sleeved calipers at the time of change over. When I sold the car, 2 quarts of silicone left over from the change over went with the car. The owner hasn't mentioned any brake problems, but I have recommended more than once that he should tear down the brakes and go thru them with new seals and hoses. Brakes shoes are not the only expendables in a brake system that need replacement from time to time. My only complaint with silicone brake fluid was that I never was able to get a rock hard pedal using the silicone fluid. Due to that experience with the '78, I have stayed with DOT 3 fluid on my other cars. As part of my brake maintenance, I bleed the brakes at least once every 1-1 1/2 years to flush out the calipers.
I also had heard back in the day that there was silicone fluid being sold as DOT 5 brake fluid that wasn't. The give away was it was being sold in unmarked quart bottles.
All my vettes (except for my '62) wear Vette Brakes sleeved calipers, and I have never had a problem with their calipers or other parts that they sell. I'm currently trying out their o-ring pistons in my '72 coupe but haven't enough seat time to form an opinion as which is better, the o-ring seal or lip seal.
Back in the '80's, there was a club member who repaired his calipers & master cylinder using JB Weld. His wife suffered brake failure at speed while autocrossing at Texas World Speedway. She & the car survived. His butt didn't after wife got thru chewing on it.
As far as rubber brake hoses go, I use the Russell DOT approved stainless steel brake hoses and have had good success with them.
Long post & Just my opinion, FWIW.
