Six speed shift knob
  • Thread starter Thread starter Dave York
Knob removal
This is copied from a poster quicksilver 1. It works well...
Well, what you will have to do, is pry up the top part, where the numbers and shift pattern are, on top of the shift knob. Then, you will see a metal key inside the knob. You will need to pry this up, and pull it up. I usually use a hook tool, and pivot off the hard plastic on the inside there.
ONce the key is out, the handle unscrews from the shifter.
I used a small pair of vise grips to pull the key out of mine. It clamped it good and a good steady pull did it. Becareful not to jerk it you my lose the rearview mirror.
