Bluemill
Both of my front Perelli P Zero/Neros have slow unfindable leaks. They loose about 5 psi per week. First I unbolted both and looked very carefully at each tire for the telltale nail or screw and found nothing. Then I took the LF to the biggest and maybe best tire store chain in the Boston metro area to break it down, and find the hole. They said it was because of pound on weights, and that was causing the pressure loss. Then they charged for glue-on balance weights.
It wasn't the case because the tire is acting just the same, about a 5 psi loss per week.
Would Slime or Fix-A- Flat be OK for the pressure sensors, or would that ruin them?
Is this a common problem? I have snugged up the inner valves as well. Mileage is 63,000. The rears have been fine. As far as I know, these are the original sensors AND batteries from 2000.
Thanks for your consideration,
Bluemill
Bluemill
