Ouch... thats a nasty scratch
Ditto...
And the paint finish looked like an excellent 10-footer (maybe a good 5-footer) too.
Talk about things "going-to-hell-in-a-hand-basket" quickly...:ugh;squint:ad
Ive seen 4 camshafts that broke in 35 PLUS years of racing and building engines
in most cases theres a good deal of internal engine damage , think about it, if the cams rotation is NOT synchronzed with the cranks rotation theres almost certainly a couple valves held open when the pistons reach TDC, when that happends the piston will bend the valves and probably spin the cam, resulting in additional cylinders bendiing valves, bent valves can and frequently do result in damaged rods, bent rods, broken pistons and cracked heads, bent rods tend to beat the crap out of the block, ETC., usually the valve covers and rocker arms, possiably the damper and water pump are salvagable
