- Moderator
- #1
- Joined
- Nov 9, 2000
- Messages
- 7,464
- Location
- Edgerton, Ohio, United States
- Corvette
- 1959 black 270hp (9/2/69) 1981 Beige L81(10/20/80)
Has anyone done a disc brake conversion on a solid axle Corvette? I am aware of the kits available from Master Power Brakes and Engineered Components Inc. but don't know of any first hand experience. Some of the NCRS guys have had bad experience with kits(I don't know who's) that use Mustang II bearings that failed. It seems that they aren't up to the extra weight of the old Corvettes.
Mooseman(Wayne) is hot on the trail of a swap using Comaro components that looks promising. If anybody has a spare pair of '53 to '62 spindles or '54 or older( I think back to '47) Chevrolet spindles that they don't need please contact Wayne. ECI makes a master cylinder mount and cylinder that allows use of your stock pedal and rod making it a bolt on.
Both of the above mentioned companys also have kits to mount GM single piston disc on the rear. Everything I have seen so far is a bolt on that can be put back to original when desired. I have always had good luck making drum brakes stop well but not as well as the '81. I think we are on the verg of finding some serious whoa for these cars.
Tom
[Edited by 59Tom on 02-05-2001 at 12:00 AM]
Tom
