- Joined
- Aug 31, 2003
- Messages
- 49
- Location
- Northern Virginia
- Corvette
- 1961 Roman Red Roadster, 1964 Riverside Red Coupe
A couple of weeks ago I had a flat tire on my 61. Had to call for roadside help since I have not (stupid me) taken the time to get a jack. It has only been 8 years! Anyway it was raining and the guy that showed up used a hydralic jack under the rear axle center to lift the car.
You guessed it he dimpled the housing at the drain plug and now the join behind the pinion has a small leak (a drip or two a day) from the widened gap.
Advice needed for the repair. Thought about heating the housing with a hand torch (with the axles pulled and oil cleaned out) to try and hammer down the distortion to the lip, then a new gasket and silicone to seal. Is there a refurb shop I can send it to that could heat and stretch the housing back to near original shape? I hate the thought of pulling down the rear end (although new bearings and seals would be a benefit) for a 4 dollar gasket and a jacklegged approach that may not work. Anybody been in this fix before?
![Rocket :r :r](/data/assets/smilies/rocket.gif)
