Valve Lash Adjustment Solid Lifters
I continue to read different methods on how to adjust the valve lash on solid lifters. Adjust cold with feeler gauge, adjust hot with feeler gauge, adjust with no feeler gauge?? The most recent was to adjust while running... Backoff adjusting nut until clatters starts, tigthen until clatter stops, 1/4 turn on nut - wait 10 seconds, repeat until one full turn is made. I know this would be a messy method, but does anyone know if this is the correct process? Does anyone have the offical GM procedure for adjusting?
I would prefer the hot method to adjust with feeler gauge when engine is not running. If this is correct, what is the correct lash for a 63, 327cu, 340hp for exh & intake?
Thanks for the help.
