regalniz
i put on a 58mm throttle body on about two months ago. dont know anything about adjusting the tps or the iac valve. just recently ive been getting about 70 miles less per tank, rough idle, and black smoke from the tailpipes. im getting no codes. i was thinking o2 sensor but im not getting any codes. i put on a new set of horns (from griots) about a month ago and i had to disconnect the battery for an hour or so. i read on this site that it takes the computer a while to get itself back to normal. is there any validity to that? if so should i wait it out or go ahead and replace the o2 sensors and adjust the iac and tps?
