ezover
I just installed is Frost King 1/8 inch self adhesive foam in the trunk of my 2000 vert. Well worth the trouble. road noise is noticably reduced in freeway driving. It took about 6 -7 hours to do.
the reflectix works great as a heat barrier, and should work as a dampener if glued down (as you described).then glued down a layer of Reflectix(the foil covered bubble wrap insulation material available at Home Depot).
