L
LarryK 87
ok, Trans fully serviced, shifts cleaner, and smoother, ( a full flush ), and new Fuel filter.
In reading some of the other posts, i now have a few new questions.
Question 1.
Just how close to the front cross member should the Crank pully be? It looks like it is almost touching it. It almost looks like if the Motor mounts are bad or even marginal that the shift of the engine would cause the pully to contact the cross member ( no appearant signs that it has, as there is a light coat of rust on the rim of the pully). And just how hard is it to replace the Mounts? ( with out a lift).
Question 2.
I had found that my interiour lights did not work due to the fuse being pulled( as a result the Climate control is also inop), Replaced the fuse with a 15a, and lights work, they just do not shut off.
i suspect this to be a problem with the delay timer which is located behind the R/S IP. So my question is how do you get the right side panels apart? I can see no mount screws accessable from the front or underside on the trim panel.
The manual kind of indicates you have to pull the TOP Dash Pad? ( not those exact words.)
Anyone been into that area yet? Suggestions?, Hints?, Tips?
Question 1.
Question 2.
