SolidLifters
- Joined
- Feb 24, 2003
- Messages
- 89
- Location
- Georgia
- Corvette
- 59 60 62 63,63,63 65 67,67 69,69,69,69,69 70
If I remember correctly the pink wire gets it's power FROM the starter solenoid. So if the harnesses under the hood are new and the pink wire isn't hot at the cowl wouldn't this indicate a bad solenoid switch? This is a recently acquired '66 L79 Convertible and I notice that in addition to the harness being all hacked up under the hood that there's a hot wire running from an auxilary position on the fuse panel through the firewall and to the ballast resistor, SO there must've been a problem with it already before the underhood harnesses were replaced.
