R
Roy M
Recently I posted a thread about different electric fans and received several good responses. I finally decided to go with the dual 11" Spal fans. Now the questions: Has anyone installed these on a stock 4 core radiator and if so, how did you fasten to the radiator. Looks like the fans will have to be shifted to the A/C side of the radiator for clearence purposes. Also, looks as if a piece of metal will have to be run across the top and bottom of the fans to hold them together as only three pop rivets holding the two fans together.
Also, does the edges of the fans (outside plastic housing) sit up right against the radiator.
Any help with the installation would be greatly appreciated. The wiring will be a breeze as it came with the relays pre-wired with enough wire to do the complete installation.
