Spare Tire
Since you asked here is a small list of things you might not know about C5, did you know:
● That you can put your key in the driver’s door and turn it twice towards the front to unlock the passenger door and a third time to pop the trunk.
● That
you can pop the trunk and also pop the gas cap cover by pulling on metal lines hidden in the back.
● The little slotted cover on the dash behind the steering wheel is where the inside air temperature sensor is located.
● All of the option codes are in the glove box.
● Tire inflation recommended pressures are on the driver’s door.
● The thing that looks like a little LED near the DIC buttons is a light sensor.
● The thing that looks like a little LED near the defroster vent is a UV sensor for determining A/C usage to compensate for the heating effect of the sun.
● The build sheet is in the front re-bar.
● If
you leave your turn signal on, in about 1 minute it will start to ding (loud enough to hear over the stereo) to let you know you have old timers disease.
You can reset the oil life by pumping the gas pedal 3 times (but not with the engine running).
● Hold down the reset button while on one of the trip odometers and it changes that reading to the miles you’ve traveled since last starting the engine.
● Hold down the Active Handling button for 5 sec. to engage “Competitive Driving” on cars equipped with active handling (2000 and previous years must be stopped.)
● If
you pull the seatbelts all the way out while you’re buckled in, they ratchet back in to hold you tighter into the seat. (then move the seat forward to make it extra snug -- Leafty)
● Simply remove fuse #2 under the hood and your DRLs will be out permanently. Only thing affected is that when
you unlock at night using the key fob your front turn signal lights and back up lights will not flash. Your front turn signals will operate normally, however.
● The side-view mirrors can twist both forward and backward, decreasing the chance of damage if struck.
● There is a release opening with a flap to let air out of the car when the hatch is closed. It is located just above the driver side rear compartment behind the carpet and on the side of the car. Not that it really works well.
● Also
you can ground your amp to a screw/bolt that holds the rear middle compartment to the frame.
● If
you have a 6-speed car you can pop the trunk when the car is running by lifting the e-brake.
● There is a spot on the driver side just out of the middle compartment under the carpet for the lug nut key.
You should have a compartment on the drivers & passenger’s side (in the trunk) and a center compartment. On the left (drivers) side of the center compartment, on the left side where the center cover fits, there is an ‘indent’ that holds the wheel lock key.
● If
you turn on the headlights, then go to parking light position, the lamps remain up but the headlights are not left on.
● If
you have the passive entry feature: If you lock the keys in the car, wait a few minutes and then shake the car. That will unlock the car.
● HUD has a shift light for the manuals.
You can easily shift the M6 trans up or down without the clutch if you match revs. (Not great for longevity, however.)
You can eject the cd from the in-dash player without turning on any power. Don’t even need key in the ignition.
● The cruise will disengage if
you purposely make sharp side to side turns while cruising at say 60-80 mph.
● When the engine is shut off,
you can get the odometer reading by turning on the parking lights.
You can program setting #3 (both memory buttons at once) in the seat memory to run the seat back and steering wheel forward for getting in/out of the car with the engine running.
● If
you hate DRLs you can pull the e-brake ONE click and they go off.
Does the 2003 corvette have a spare tire?
If I'm not mistaken, you've just bought your C5, right?
If so, here's a thread in the C5 General Discussion forum with links of interest to a new C5 owner.
New to the C5 world
And I just made this post in another thread in which you were inquiring about runflats.
Flat tire at 80+ MPH
Hope some of this helps.
:wJane Ann
I'm ashamed of all of you. Of course there is a jack on a C-5. See:
This jack is used to put the C-5 spare on. See:
There is no factory spare or jack in any C5 or C6 Corvette. Except for the Z06, all C5's came from the factory with "run flat" tires and a tire pressure monitoring system. The Z06 came with standard (not run flat) tires, and some tire goo and an air pump provided by the factory. Some people like to remove the run flats from coupes and convertibles and purchase some type of tire repair/air pump kits. However, putting tire goo inside a wheel with the tire pressure sensor in it will ruin that sensor. So it comes down to what your preference is and the level of risk that you are willing to accept.
But you have no jack and no spare in a C5.
OK - here is the deal: obviously C-5's don't have jacks and spares. As prior posts have stated, coupes and FRCs have runflats. ZO6 have regular tires with "slime" kit.
I switched from RF to regular for improved ride. The reality of RFs are they will generally get you off the road in a deflation scenario, but 99% of the tire shops (and 100% of the redneck tire shops that are in every small town) can not touch RF for repairs.
I carry the jack posted above along with a small tire inflator and plug kit. On long trips, I throw the spare pictured in the back.
The jack is a small jack that I customized with a built-in spacer to protect the rocker panels. The spare tire is from a 2005 GTO. It has the right lug pattern and offset. The diameter is .25" less than the back tires (and thus does not adversely effect the drive train). It is slightly larger than the front tires, but it is insignificant. The tire fits both front and back.
SEE YA!
ETA: bought the spare off of E-bay for $40.
● That
● If
you leave your turn signal on, in about 1 minute it will start to ding (loud enough to hear over the stereo) to let youknowyou have old timers disease.
● If
● Also
● If
● If
● If
● If
Most of that is true, but not all of it. That is not how my oil monitor is reset, for example. And the e-brake DRL trick does not work on my car. Also, it is not advisable to rotate the side mirrors unnecessarily. They are prone to breakage. There are multiple threads concerning this issue. But it is a very nice summary of some things that you can do. It is also useful to be able to read diagnostic codes (DTC's) on the driver information center. There is a sticky thread at the top of the C5 forum that tells you how it is done.
......... It is also useful to be able to read diagnostic codes (DTC's) on the driver information center. There is a sticky thread at the top of the C5 forum that tells you how it is done.
That thread and several others useful to new C5 owners are also in the link in this post:
Post #22 Click
.......If I'm not mistaken, you've just bought your C5, right?
New to the C5 world
FIX-A-FLAT will fix your pressure sensors, for good. Never use it with tire pressure sensors, never.
yes, but the cost to replace a sensor is much less than the difference of the runflats.
