spark plug/heat range issue
  • Thread starter Thread starter jon79flavette
J
jon79flavette
I am running into a problem with early fouling of plugs. The motor runs like a champ, then after an hour or so of run time it deterorates rapidly. new plugs and I am back to good. I am running NGK r-5673-7. I am going to try the 6 NGK instead of the 7. a little bit hotter plug. Does anyone know if this will make a significant difference??? Or any other plug suggestions? Will the 7 heat range have a tendency to foul that quickly? or are there other issues?? I have been doing more around town driving, so this may accelerate the problem. Any thoughts appreciated. Jon
P.S. motor is a 70 LT-1, modified to about 420 h.p. running a 280/520 cam, holly 750 double pump, dual feed, if engine info helps. ported cast heads with 1.6 rockers.
My own opinion NGK's are most of the problem. Try Autolite or AC's. I always used AC's in the race car without a problem.
Just my .02..........:beer
My stock 350 with a spread bore Holley was running rich. A magazine article says to adjust the idle screws on the sides of the bowl using a vacume gauge. Adjust to highes vacume. This worked great. It worked out to about 3 turns out on each side. I never had a Chevy to idle so good.
as far as the autolite or others, do you have any suggestions. The NGK is a race plug, and seems to be recommeded by several people. We have a moroso track near by, and while this is more of a strret car than strip, they seem to like the NGK v-power race plug.
Sounds to me your plugs are too cold.
1 or 2 steps hotter should help your problem.
I also agree with Ron, lose the NGK's and put in AC or Champs!
Good Luck! gary.
