J
jon79flavette
I am running into a problem with early fouling of plugs. The motor runs like a champ, then after an hour or so of run time it deterorates rapidly. new plugs and I am back to good. I am running NGK r-5673-7. I am going to try the 6 NGK instead of the 7. a little bit hotter plug. Does anyone know if this will make a significant difference??? Or any other plug suggestions? Will the 7 heat range have a tendency to foul that quickly? or are there other issues?? I have been doing more around town driving, so this may accelerate the problem. Any thoughts appreciated. Jon
P.S. motor is a 70 LT-1, modified to about 420 h.p. running a 280/520 cam, holly 750 double pump, dual feed, if engine info helps. ported cast heads with 1.6 rockers.
