Stage Left
I think I'm going nut's
First it was the oil filter deal PF25 Vs the new PF454 not having the same rubber seal size as the PF25. So I'm using a Purolator oil filter PL20049
Now I just pulled a spark plug, and went to buy a new set. Same AC R45TS number, but the plug is not the same dimension as the old one. I only own the car for a short time, this plug could be close to the original set??? 1975
The original plug ground electrode is longer/deeper into the engine head with a shorter outside ceramic wire connection.
So the new plug groung electrode is shorter / into the engine head with a longer outside ceramic wire connection.
Did AC Delco make a change in the early years and stayed with the same spark plug number???
I did go back to the auto store and pulled one more set, same deal...
Anybody know....
Anybody know....
