For the record, what plugs were you recommended, for the 396 or the 454, or something completely different?
Craig
My main delema was (the PO) having gone from an open chamber 122cc head to a 97cc closed chamber head on a completely different engine and how that would affect plug selection and whether or not the head was the only compelling variable in this case. Parts counters here are computer screen readers only and could tell me what plug was used for the 396 CID
if I knew the HP and year, with the heat range being the only discernable difference.
So, after some research and a lot of good input, it all seemed to come down to whether to use a R43XLS or a R44XLS. So
as a starting point, I chose the latter. We'll see where we go from there.
I am not a "Big block" guy so I dont know for sure but I believe 97cc is a little small for a street engine of that (454) size.
Craig sr.
Not my baleywick, but by my calculations with all things being equal, going from 122cc to 97cc would change the CR from 8.5:1 to about 10.4:1. Whether or not you have a point remains in question. I don't know the answer either.
Looks like your PO used the equivalent of an AC43. If these are working well for you, why change?
The plugs were a Denso number that is not easily obtained around here for some reason. The cross reference was fine I guess, if I knew what factors were taken into account when he selected the Densos and if he knew whether the heads were not from a 454 Corvette engine. So, I set out on a mission to actually
learn something about the whys and why-fors, knowing I had a missmatched block/head pair.
I guess it all came down to trust, and wanting to not repeat a mistake simply because someone else did. Plus, having only put a couple hundred miles on the car since purchasing it, it's hard to say if they were working for me, especially since the Densos looked like a little "cold" running plug.
Plus it never hurts to get alternative opinions when you're not an engine guru!
BTW - I guess it's a good thing you didn't see my thread on spark plug crush gaskets on another forum! :L
