The fuel smell is more than likely is a result of a missing or poor performing vapor canister. On my 73, the canister was removed along with all its plumbing. There is a vapor line that runs from the top of the gas tank along the inside of the frame on the driver's side that is supposed to be connected to the vapor canister, which is supposed to be located in front of the driver's side floor pan. The vapor canister is full of charcoal and it has a filter in the bottom. If your can is there, then the filter will need to be changed. Two lines on top of the canister should be routed to your carb vacuum lines. One should be routed through a PVC valve in your drivers side valve cover. The idea is that the carb sucks in the vapors and burns them. Your assembly manual will show you the connections. If all of that stuff is missing from your car, then the fuel vapor line has probably been cut and is venting fumes inside your car and garage. If you need help, let me know. Move done a bunch or research on this andmcan point you towards several resources.
