R
rsmlap
Does anyone know the color of the stock speedometer gear in a 1981 350 with Automatic trans?
Welcome to CACC! Can't help you with that except to offer suggestion: I believe your color (which indicates number of teeth) will be specific to your rear axle gear ratio. Perhaps if you posted your axle ratio, someone may be able to xref that to correct speedo gear (color).rsmlap said:Does anyone know the color of the stock speedometer gear in a 1981 350 with Automatic trans?
