C
clar2001
I installed a #330 composit spring on my 75 I torqued the plate bolts to 65lbs and the plate bent the two bolts closest to the rear of the car are want won't stay torqued, the plate bends in the middle and on the out side corners, my chiltons manual said 50-75 lbs so I installed a second plate and only torqued to 50 lbs and trhis plate bent too, any ideas what im doing wrong I slowely tighten bolts until reaching torq level .
This spring unlike the stock one has a rubber pad on top and bottom of it.
